Old 11-04-2007
Tartan34C Tartan34C is offline
Tartan34C will become famous soon enough
Originally Posted by Boasun View Post
the metal band at the outboard end of the bowsprit is the 'Spider Band'.
Most of the other terms in the drawing are right on otherwise...
I hate to disagree but a spider band is the same thing, that is to say a band on a spar but it’s on a mast and it has cleats or belaying pins built in so it can look like a spider to drunk sailor with poor vision. And if you add a ring to a cranes iron for another spar to slide in such as a topmast or boom for a studding sail the cranes iron is now called a wythe iron.
All the best,
Robert Gainer
Study the history of naval architecture and move forward knowing what didn’t work before.
Don’t waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
