Merttan-
It really depends on what your primary goals for the boat are. If you're going to be racing her alot...then get the deeper draft... you'll do better as the boat will point higher. If you're really interested in cruising, get a shoal draft boat. There are a lot more interesting places you can go with a shoal draft boat. Also, if you like gunkholing, a shoal draft is a requirement.
Finding a 30' boat with over six feet of head room will be a bit of a challenge, but I would also remind you that you need to check out the berths. Doesn't make much sense to get a boat that you can stand up in, if you can't find a place to sleep on it.
In this regards, us short people got a lot more options.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
