Old 11-06-2007
Craig Smith's Avatar
Craig Smith Craig Smith is offline
Rocna Anchors
Craig Smith is on a distinguished road
Arrow
Originally Posted by nickvh View Post
On a Beneteau 473 with a Lewmar H3 windlass - i want to put 300ft chain. Does anyone have experience of that much chain up there in the bow locker causing performance issues because 3/8inch BBB is almost 500lbs in weight and that sounds like a lot! I was hoping to use HT 3/8 chain wich is much lighter but the pitch is such that its not a good idea!
Much lighter?
I assume you mean hi-test instead of HT, as actual HT of the same size as BBB would be far (unnecessarily) stronger.
If you really need 300', the solution here is to use HT (that's high tensile - G70) of the same or slightly better SWL, but truly much lighter than equivalent hi-test G40 (let alone BBB / G30). You'll need to look at switching the wildcat, talk to Lewmar.
Craig Smith
Rocna Anchors
