SailNet Community - View Single Post - Winter Sailing
Thread: Winter Sailing
post #7 of Old 11-07-2007
TrueBlue
Seņor Member
TrueBlue's Avatar
Originally Posted by RickBowman View Post
TB,
Where would the 50/50 mixture be added and what does it consist of?
Rick, Is this a trick question?
Anti-freeze is only effective when mixed in a 50% solution with water. It's of course, used in the closed fresh water cooling section; but during winter layup, I prefer to run it through the raw water section as well.
As you clearly pointed out in your previous post, sea water does freeze and there's no assurance all can be drained from the system. The anti-corrosion additives also help protect the c.i. engine components from rusting.
True Blue . . .
sold the Nauticat
TrueBlue is offline
