Originally Posted by labatt
We'll put the solar vents on the angles, so they should remain uncovered most of the time. I'd be interested to hear anyone else's experience with them too. Also, we plan on getting a "door" for the shrink wrap too.
I wouldn't bother with trying to rig solar vents. To me that's getting a bit paranoid about the falacy that shink wrap = dampness. The plastic Clam Shell Vents purchased from the same companies that sell the shrink wrap is all you need. YOU control the ventilation of your wrap if you are doing it, and if you don't, simply tell the wrappers how many vents you want and where. Of course if you do a swiss cheese version of a patchwork quilt as I did last year you don't have to add any vents at all
You can also purchase zippered doors from the shrink wrap catalogs that can be cut out and used for a few years. I added frame stand-offs to keep my frame a couple inches outside the teak hand rails at the top of the stanchions so I can do the annual light sand and re-coat under wraps in the spring - which also aids in ventilation because the bottom of the wrap will be wrapped around a line inches from the hull - unlike the paid wrappers who usually have that line touching the hull which may be a problem in itself. Some people at my marina who pay to have it done add a stand-off around the gunwale area to keep that from happening.
