SailNet Community - View Single Post - Sizing battery cables
post #6 of Old 11-08-2007
sailingdog
Not if it is a slow-blow fuse. If the starter motor is rated for 60 Amps... and you put a 60 amp slow-blow fuse on the line, you should be okay, since the in-rush current duration is so short, it won't generally cause the fuse to blow.
Originally Posted by Idiens View Post
I think the question was about the fuse size. If you put a 50 amp fuse on a starter motor cable, expect it to blow.
sailingdog is offline
