SailNet Community - View Single Post - trolling motor on dinghy
post #2 of Old 11-10-2007
sailingdog
randy-
there was a thread on this very subject earlier this year, you might want to search for it. Personally, I'm not a big fan of the idea. Here's my reasoning.
If you use a trolling motor and battery, you're probably looking at 20 lbs for the trolling motor and at least 30 lbs. for the battery. A 3.5 HP four-stroke motor with 1/3 gallon fuel tank weighs about 36 lbs. A one gallon tank of gasoline weighs about 10 lbs. With the internal tank full, and the external one gallon tank, you can run for about four hours, and getting more fuel is generally quite simple. IIRC, the electric trolling motor and battery won't run as long, or be as easy to re-fuel, or give as much power in general.
Adding a solar panel just adds complexity to the dinghy setup, and is just one more thing that can be stolen from the dinghy.
sailingdog is offline
