SailNet Community - View Single Post - Gross problem
Thread: Gross problem
post #4 of Old 11-13-2007
rennisaint
rennisaint's Avatar
Does your pump have a manual crank output so you can crank it backwards to try to dislodge the.... whatever? Can you disconnect the downstream side of the pump and hook it up to a pressure line and try to blow the pump backwards (Probably best done after your holding tank is emptied). Otherwise..... be happy you don't get to play with gray water every day, and tear her apart and have fun! Remember, your **** is my bread and butter.
rennisaint is offline
