Valiente-
Any of the Link battery monitors will work with the RS... but the Link 1000/2000 are more expensive since they have the ability to control Freedom series inverter/charger units. If you want to monitor two banks, get the Link 20, if just one, get the Link 10.
Think about it for a moment... why would Xantrex make a battery monitor that you couldn't use with any of the chargers it makes? That would be pretty stupid. The only real difference between the Link 10/20 and the Link 1000/2000 is the fact that the Link 1000/2000 can control the Freedom series of inverter/charger units... which the Link 10/20 can't.
I am still wondering what idiot told you that you couldn't use the Link 10/20 with the RS2000.
There is nothing in any of the literature or specifications that says you can't use the Link 10/20 with any battery charger. If you had a Freedom series inverter/charger, getting the Link 1000/2000 would make a bit more sense, since it can be used to control the Freedom unit... but there is absolutely no reason you couldn't use the Link 10/20 with the Freedom series units either.
