  #14 (permalink)
Old 11-16-2007
sailingdog sailingdog is offline
Interesting... I was going by the owner's manual for the Link 20, which doesn't mention it at all.
BTW, I believe that Hoffa means that you should shut down/disconnect the solar/wind if you're charging the batteries on shore power using the Xantrex. The higher voltage caused by the solar/wind sources can fool the Xantrex into thinking the batteries are actually fully charged when they're not.
