  #20 (permalink)
Old 11-17-2007
HoffaLives's Avatar
HoffaLives HoffaLives is offline
HoffaLives is on a distinguished road
It's really important to sit down and work out a power budget, and be scrupulous. There are small systems that are running and are easy to forget about, like a sniffer, a propane shut off solenoid, radio, and so forth. To be realistic you should list everything and to be safe double it, and you'll probably be closer to real consumption. And you likely are aware that these alternative power sources very rarely achieve anything close to their rated output. That's why it's important to have the best charging system you can afford.
And while redundancy is a very good idea, remember that reliability tends to suffer the more complex the system is.
red peril
severodvinsk class russian submarine
1993
364 feet
our life afloat:
