Old 11-17-2007
sailingdog sailingdog is offline
A blood knot would work, but I'd use a Fisherman's Knot, which is basically an overhand knot tied around the standing part of each end. It uses less line than a blood knot and takes up less space.
Once the two knots are jammed up against each other, this knot is very unlikely to come loose. The higher the load, the better it generally holds.
