SailNet Community - View Single Post - Bronze portlight install
post #3 of Old 11-20-2007
sailingdog
GBurton-
I would use silicon bronze screws, but you could probably get away with using stainless steel acorn nuts on the interior, especially if you use TefGel or LanOcote to prevent galvanic corrosion issues. The interior should be dry... so the real dangers of galvanic corrosion are minimal—unless you've done a really lousy job of installing the ports.
sailingdog is offline
