Old 11-21-2007
sailingdog sailingdog is offline
Denise-
If you're planning on barrier coating your boat, I would use the Interlux Interprotect 2000. Get four gallons, two of white, two of grey, and then coat with a layer of grey, a layer of white, a layer of grey and finish with a layer of white. That should give you good coverage and make coating the areas with the stands fairly easy.
