Need ''''survey on the hard'''' advice
Having a couple of surveys that didn''t make it off the hard I will say that most everything can be tested without a sea trial.
Can run engine but not sure how you could put a load on it. But could do compression test for sure... Since you will be shipping you''ll be taking the mast down and will be able to look at it better than even an agile surveyor. Doubt that renegotation is a real possibilty as by the time you have it in Fla you will have put a lot into it. Am assuming it is small enough that shipping is reasonable?
