SailNet Community - View Single Post - Singlehanding
Thread: Singlehanding
post #15 of Old 11-25-2007
Tartan34C
Originally Posted by RandyonR3 View Post
The line drops to the deck and is run back to the cockpit.. If you pull on the line, it take the bag out of the sail and the sides flop in the wind.. If you drop the halyard and reliese the sheets, you could pull the kite right back down the side of the boat... On my smaller boat I had a bag at the companian way that I would shove the kite into..
On my First-42, i have a sleave, or sock that pulls down over the kit.
The main reason for the belly button ring, is for emergencies to deflate the sail....
OK, I got it now. An interesting idea and I need to think about it a bit.
Thanks,
Robert Gainer
Study the history of naval architecture and move forward knowing what didnít work before.
Donít waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
Tartan34C is offline
