SailNet Community - View Single Post - More 12v Troubles and ?'s
post #7 of Old 11-26-2007
sailingdog
Most stereos that require a memory or clock maintenance lead, will have a separate lead with a very small, usually 1 amp, fuse for it. This should be connected directly to the battery for the reasons stated above... but the radio's power lead, with a much larger fuse, should be switched and overload protected in some way.
As for bonding... bonding them to each other can be a good sign, but it often isn't necessary or wise to do so. Galvanically isolated metal throughhulls may not benefit from bonding. It really depends on the specific boat setup.
BTW, the copper on those bars looks like it is starting to corrode. I am willing to bet if you were to put the leads off an ohmmeter on them, it would register some resistance, rather than pure short due to the oxidation on the surface.
sailingdog is offline
