  #566 (permalink)
Old 11-27-2007
poopdeckpappy's Avatar
poopdeckpappy poopdeckpappy is offline
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Originally Posted by StuMyers View Post
2. Conclusively show that the additional concentrations of GHG's have a source OTHER than the KNOWN properties of power plants (good luck).
It's my understanding that CH4 is second only to C02 as a GHG, but CH4 is 21times more effective at trapping solar heat than carbon dioxide.
There are vast stockpiles of frozen methane on seafloors and there are vast areas of permafrost being exposed every day and all releasing CH4
They found evidence that methane trapped in ice crystals was released into the water 44,000 years ago at the same time there was a rapid, but as yet unexplained, rise in global temperatures.
This rise in temp has been fluctuating over the last few thousand years, but also has been on the rise; So as the temps rise, the land and seas warm, which releases even more CH4 from the frozen ice crystals in the oceans and also from the permafrost, which again leads to more CH4 being released.
To me, this is far more likely the source and cause of your/our problem and NOT CO2, but then, it's easier to politisize and hype the carbon dioxide increases for the global warming alarmist than it is to politisize and hype a gas that is being released naturally and again it's a gas that is 21 times more effective at trapping solar heat.
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
