Stainless steel is not great. Corrodes. Plastic is very good. it would be a good idea to create the places where you want to put the tanks and then have plastic tanks made to fit in. You could do it so that the whole top of the tank came off for easy cleaning.
It's hard to avoid chemical taste when you have your drinking water sitting in fibreglass or epoxy resin. It can also seep into the hull if you haven't sealed it perfectly, which is harder to do than it sounds.
