Building a head tank
Opinions: I am thinking of getting rid of my porta potti and installing a holding tank. Under the V berth was once 40 gallons of water tankage that a previous owner opened up for storage. The old tank is actually an integral part of the molded pan for for the interior of the boat. Under the V birth they molded the pan into a deep v tank and then covered the top flat, where the cushions sit upon, with 1/2 plywood that had the tankside surface laminated. Opening up the plywood top, one sees a V shaped tank, wider aft and getting narrower and shallower forward. The interior of the tank is the same gel coating used throughout the cabin pan. I am thinking of using 20 gallons or so of of this tank as my new holding tank. I would fit a piece of glass sheathed plywood as a wall, and glass it solidly to the inside of the old tank, which would now be part holding tank and part storage. I have not yet thought out the cover - though either glassing it on, or making it removable w/gasket and lots of screws is a possibility. Holding tank modifications are serious stuff and one does not want a shoddy plan. Any thoughts?
