SailNet Community - View Single Post - contol lines mainsail, lancer 30
post #3 of Old 12-20-2002
Jeff_H
Moderator
Jeff_H's Avatar
More likely than not, the center line is the outhaul and has a tackle in the boom to give you greater machanical advantage and the two outboard lines are clew reef lines for a slab reefing system. The reef lines run from the end of the boom, through the reef cringle and then are typcially tied around the boom at a point aft of the reef cringle in the reefed position.
Jeff_H is offline
