SailNet Community - View Single Post - Engine Room/Compartment Paint
post #2 of Old 12-04-2007
sailingdog
The bilge under the engine I would paint using a barrier coat paint, like Interprotect 2000E.. It will help protect the fiberglass from osmosis from the bilge to the exterior. It should be just fine on the fiberglass, given that the fiberglass isn't bothered by the temperature, it shouldn't be either. You could probably use it on the plywood, MDF and underside of the cockpit footwell too, but if you do that, I'd go with the white, rather than the gray.
IMHO, it shouldn't get hot enough to damage the paint, given that it isn't damaging the fiberglass, wood or MDF. You might want to call Interlux and see what they say about using it for this particular project.
sailingdog is offline
