SailNet Community - View Single Post - Outboard Running Problems
post #7 of Old 12-09-2007
camaraderie
moderate?
camaraderie's Avatar
I assume you are using the internal tank on the engine...per Pub's suggestion...drain and refill with new gas/oil mixture.
You may also have some laquering of the carbeurator and or some water in the fuel bowl.
Try some carbeurator spray first...if that does not work, you may need to dis-assemble and clean it all out.
camaraderie is offline
