Thanks Cam . Yes I set the batt capacity to 625 and yes I do have trouble when at dockside. Last time I plugged in the monitor was displaying 15 V Waaaay to high but my portable gps was showing only about 13.7 so I checked Vcoming into the batts at the charger leads and they matched almost exactly the GPS display. Then I checked V coming out and they showed just a little less. Also when the link went to float it was displaying about 13.9 when it should only be about 13.2 I compensated for this ( short term) by changing the batt temp adjustment which will allow you to change the float Volts.
I am in Miami Now awaiting a descent wx window to cross to Bimini and thought that when I bought the gen I would have solved the other prob that I have wich is a poorly insulated fridge that will only stay below 0 for a half hr after the eng is shut down( eng drive compressor) then I could charge batts with the Honda and run the fridge on AC , That is a different subject however nad any comments on the charging are VERY appreaciated.
I will try plugging in some lights as you described Thekiep when the other boats in the anchorage have woken up , as the honda gets quite loud when it try to give teverything it has to Solange IV
Thaks K
