SailNet Community - View Single Post - Limit of Positive Stability (LPS)
post #15 of Old 12-11-2007
KeelHaulin
STARBOARD!!
KeelHaulin's Avatar
I think the problem with your calculation is that you are entering the draft of the keel; not the hull draft. For a Catalina 42 the hull draft should be somewhere in the range of 1-2 feet and that would give an AVS result somewhre in the 118-130 deg range.
Use the following page for entering numbers; remember to use hull draft not keel draft:
http://www.sailingusa.info/cal__avs.htm
KeelHaulin is offline
