SailNet Community - View Single Post - Buying a Sailboat from the Great Lakes
post #2 of Old 01-12-2003
Bart Toby
Gaucho47
Freeze thaw period can be tought on a fresh water boat; when water enters areas that were not designed to be wet.
ie.: under deck fittings which have loosen, under normal use over time. This allows a little water to enter during the summer and then expanding over the winters. If gone un-notice, which is fairly normal, this cycle repeats it self year after year until it is to late.
When walking on a deck and one notices deflection or see brown water stains on the under side of the deck this boat is in need of a deck repair.
as for other areas of the boat on the plus side for "fresh water", I would think the be.
engine,
Electrical,
rigging, standing and running.
negitive side of fresh water,
decks,
teak,
poorly supported hull''s while in cradle,
hope this helps
Bart
Bart Toby is offline
