SailNet Community - View Single Post - Swage vs mechanical fittings
post #7 of Old 12-16-2007
Sapperwhite
Not So Senior Member
Sapperwhite's Avatar
I re-rigged my entire boat top to bottom with Hi-Mod fittings, and I can say it was pretty easy going. The crown inside the fitting that accepts the wire strands works great and makes it easy. You would have to try hard if you wanted to botch the procedure. Just remember to measure 5 times, cut once (Okay, so I'm a little OCD). I know alot of cruisers that swear by Norseman just because replacements can be found almost everywhere in the world, which might not be so easy with Hi-Mod. If that isn't a concern, I highly endorse the Hi-Mod fittings just because they are so damn easy.
Dictated, but not read.
Sapperwhite is offline
