SailNet Community - View Single Post - Swage vs mechanical fittings
post #10 of Old 12-16-2007
sailingdog
I'd go with Hayn Hi-mods, as they are the easiest to install and maintain IMHO.
Properly done, rod rigging is very long lasting and very durable... but the key to that is if it is properly done. If the cold-formed heads aren't done right, they will fail catastrophically with little or no warning...
You could go with swaged fittings, but IMHO, mechanical fittings are more reliable, since a bad swage is hard to determine visually and they're more prone to corrosion problems as well.
Personally, if you're planning on cruising long-term, I think that mechanical fittings and wire rigging is the best way to go... carrying spare rod rigging is difficult at best, and fitting wire to the rod terminal points is often very difficult. Mechanical fittings allow you to easily do repairs and carry spares.
sailingdog is offline
