SailNet Community - View Single Post - buildup in poo hose
post #3 of Old 12-18-2007
camaraderie
moderate?
camaraderie's Avatar
It is not shells...it is what happens when uric acid mixes with salt water. The standard preventative treatment is to flush vinegar slowly through the system once a month...over a couple of hours.
Once you HAVE the problem...the solution is to flush muriatic acid through the system. Do a search here on muriatic for a complete procedure. Problem solved.
camaraderie is offline
