  #17 (permalink)
Old 12-19-2007
TrueBlue's Avatar
TrueBlue TrueBlue is offline
Seņor Member
TrueBlue is a jewel in the roughTrueBlue is a jewel in the roughTrueBlue is a jewel in the rough
The problem Hoff, is with capillary action wicking water under and into any spaces occuring between mated components. Under normal - above freeze conditions, there is no problem. The water will simply evaporate, or eventually drain out and not result in internal leaks.
As this water expands however, these mated parts are at risk of separating, possibly compromising the fastener's hold - even ripping a section of GRP or teak away in the process. Now you have a water intrusion issue with cored deck, into cabins below, or frost heave of teak decking. I don't have coring, solid glass under my teak decking. But I cover to protect everything else.
True Blue . . .
sold the Nauticat
