SailNet Community - View Single Post - Tiller auto pilots
Old 01-21-2003
thefantasea thefantasea is offline
thefantasea is on a distinguished road
Tiller auto pilots
You write:
"Interfacing -- my tillerpilot has a "nav lock" mode, where it alters set course as necessary to stay on the track programmed into the GPS. While this offers the possibility of automatically correcting for set and drift, I refuse to run an autopilot in "nav lock" mode, because I consider it hazardous for a sailboat to potentially change course on its own initiative."
I, too, have a Navico Tiller Pilot. When I use it I plot my course between two points on a chart. This establishes a straight line compass course to be sailed and becomes the initial heading. Various forces acting on the boat combine to push it from this line. This introduces cross track error which, depending on the severity of the forces, can mount quickly. Although the pilot maintains the original heading, Loran or GPS readings show the cross track error at a given time. (Cross track error can be thought of as the accumulated leeway the boat has made.)
Plotting the boat''s L&L coordinates on the chart and drawing a heading line from it would show that the boat was sailing a course that is parallel to but separated from the original plotted line by the distance of the reported cross track error.
To reach the target a new course has to be plotted and the compass heading of the pilot adjusted accordingly. As soon as the pilot is set to the new course, the cross track error commences anew. Ang again, and again.
If one was sailing parallel to the shore a mile off in conditions of poor visibility, uncorrected cross track error of one mile could result in a beached boat.
The pilot maintains the compass heading by making a great number of small but frequent course corrections. Coupling the pilot to a Loran or GPS constantly feeds the information needed to compensate for cross track error thereby keeping the boat precisely on the chart line first drawn. The course changes remain undetectable, as before.
I believe that coupling the pilot to a Loran or GPS enhances the level of safety. Of course, a prudent sailor makes frequent chart position plots to verify his progress along a route.
