SailNet Community - View Single Post - True Grit
Thread: True Grit
post #9 of Old 01-22-2003
Jeff_H
Moderator
Jeff_H's Avatar
True Grit
What can be a merely expensive repair could become a more expensive repair than the boat is worth as you literally end up laminating a new bottom. The problem with blisters is that they expose the open ends of the glass fiber. This permits moisture to move deeper into the laminate and potentially create the kinds of pressure that pried the laminate apart and allows water even deeper access. Eventually you have what looks like a boat but which structurally is no longer a boat.
Jeff_H is offline
