SailNet Community - View Single Post - Troubleshooting Depth Sounder
post #10 of Old 12-31-2007
sailingdog
A visual inspection of the pins and socket will generally tell you if corrosion is the issue. I don't believe that's your problem—since it works intermittently, without your wiggling the wires.
It could be internal corrosion or a bad IC chip. My bet is that there was a flaky chip that had a thermal fault and as you used it, the heat from use caused it to become progressively worse, until it has basically failed completely.
sailingdog is offline
