SailNet Community - View Single Post - Patching water tank?
post #11 of Old 01-03-2008
deerenick
I have repaired leaking plastic fuel tanks with the expandable plugs that you can get at the hardware,you must first drill a clean hole through the old one then insert the plug and tighten the machine screw to expand the plug.I would replace the plated screw with stainless.(note)will only work with a punched hole and not a crack line.Good luck.Bill NC
deerenick is offline
