Old 01-04-2008
kenstuber kenstuber is offline
kenstuber is on a distinguished road
Jim,
I installed a high capacity electric bilge pump and float switch on my B32. I attached it to a long piece of aluminum angle stock with tie wraps. The top of the stock is attached to the the boat's shower water pump wood base assembly. This allows the pump to be easily lifted out of the bilge for cleaning, inspection, etc. I ran the electric pump's discharge hose to the the existing thru-hull on the stern of the boat. This was done by inserted a tee in the existing hose that is utilized for the manual pump. The system works well.
Regards, Ken
