SailNet Community - View Single Post - Staying Warm and Dry at Sea
post #23 of Old 01-04-2008
wind_magic
Originally Posted by SVAuspicious View Post
I had a heated vest (from a company called Eclipse IIRC) when I was riding year round. It was great under winter motorcycle gear or a snowmobile suit. The vest was plenty to keep my whole body warm. The only downsides on a boat are unplugging and plugging when you have to leave the cockpit and the power drain.
I read up on the power drain because that is a concern of mine too, and it is certainly not non-existent. Using Gerbing as an example, they say that the socks use about 1.8 - 2.1 amps (at 12vdc'ish), pants 3.6 - 4 amps, and a vest liner uses 4.5 - 4.6. That's about 11 amps for the whole outfit, or 130 watts continuous. That's enough to be concerned about if all you had were solar panels, though it probably wouldn't be a concern at all with a wind generator in winter.
I ordered something earlier today to try it out and see how well they work.
What are you pretending not to know ?
Please support my
wind_magic is offline
