SailNet Community - View Single Post - Cutting floor board?
post #6 of Old 01-06-2008
sailingdog
Halekai's description is basically what I would recommend... adding that you really want to use the narrowest, finest toothed circular saw blade to make the majority of the cuts, and then cut the corners using a jig saw with a very fine toothed blade.
One other thing, you will probably want to set the blade depth on the circular saw to just a bit more than the panel thickness, to minimize the damage to any floors or stringers that may be under the opening your cutting.
sailingdog is offline
