SailNet Community - View Single Post - Fiberglass (delamination??) repair
post #4 of Old 02-20-2001
RichH
RichH's Avatar
Repair:.... make a tiny hole to inject the mixed resin with a large plastic syringe. If you have access to a paramedic or nurse or physician.. get a very large bore hypodermic needle to attach to the syringe. Make a very teeny hole to allow air venting while you inject. Mix up the resin and push it in with the loaded syringe. Keep the injection holes as absolutely as small as you can... less surface repair.
Tape over the whole area with masking tape before you inject so you dont ''spill'' resin on the surface.
Airex is ''plastic foam'' used for core material... You could also have balsa core.... Airex seems to bond less well than balsa.
Good luck.
RichH is offline
