SailNet Community - View Single Post - Fractional Rig vs. Mast Head Rig
Old 01-06-2008
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
I also own a fractionally rigged boat which does not require running backstays. My boat was sailed in from South Africa on her own bottom without them. I typically sail with a 110% jib except in the lightest breezes at which time I shift up to a 130% jib. The boat is fast and easy to handle on all points of sail. The following was a piece that I wrote for another purpose on this subject.....
Fractional vs. Masthead rigs
These terms both derive from the point at which the forestay hits the mast. On a masthead rig the forestay hits the mast at the masthead (top of the mast). Masthead rigs are far and away the more common of the two rigs. Historically cruising and racing boats were fractionally rigged. The Masthead rig came into popularity as a racing rule beating method for racing sailboats. Under the CCA and IOR racing rating rules, jib size was under penalized. This promoted small mainsails and big masthead jibs and spinackers.
On a fractional rig, the forestay hits the mast somewhere below the masthead (or a fraction of the overall height of the mast. It is not unusual to see fractional rigs referred to as a 2/3 (Folkboats), 3/4 (J-24) or 7/8th’s (Triton) rig.
Each rig has it advantages and disadvantages. There are some big advantages to a fractional rig for cruising and racing. For cruising you are dealing with smaller and easier to handle headsails Not only are the headsails smaller because of the shorter headsails but, because the headsails represent a smaller percentage of the overall sail area, you often do not need to have overlapping jibs. The sail area is made up in the mainsail.
Fractional rigs often have purposely designed flexible masts and, when combined with a backstay adjuster permits quick, on the fly, depowering of both sails. Mainsails are easier to reef in a manner that results in an efficiently shaped sail for heavier conditions. It means that you don’t have to take the expense, complication, maintenance and performance hit of a mainsail furler. Controlling mast bend you can often avoid reefing as the winds build. Roller furling genoas have notoriously poor shape when partially furled. The smaller jibs of a fractional rig rarely need reefing and when they do the fact that they are non-overlapping results in a better partially furled shape.
Masthead rigs have larger running sails and so can typically point closer to dead down wind. They are a little more forgiving. Because Fractional rigs permit such a large range of easy adjustment they can be trimmed through a range of adjustments that results in a bigger range of speed both slower or faster than a masthead rig of similar sail area. The limited adjustment of a masthead rig means that you more or less live with what you have. Therefore a masthead rig neither has the opportunity for going really faster and with less heel, or going much slower either.
My biggest problem with Masthead rigs is that you really need to carry more headsails and make more headsail changes. This is partially a function of the responsibility of the jib for drive. If you take a Fractional Rig 100% jib on a 28-footer it might be 150 s.f. and its 150% Genoa would be 225 square feet. But on a masthead rig 28 footer the 100% jib might be as much as 225 to 250 square feet and its 150% Genoa would be 337 S.F. to 375 s.f. That is a really big sail to manhandle and the when you increase a sail by 125 S.F. vs. only 75 s.f. there is a much smaller wind range that the bigger sail can be carried in so you might end up also carrying a number 2 Genoa as well as a working jib and a 150% #1 Genoa. With roller furling you end up sailing more frequently with (much less efficient) partially rolled up sails.
I strongly favor Fractional rigs for coastal sailing because the are so much easier to tack and jibe, you are not carrying around the big winches and as many large sails, and you are not subjecting the boat to the much higher loads of a masthead rig.
