SailNet Community - View Single Post - Cutting through hole
post #2 of Old 01-07-2008
Sasha_V
Sasha_V's Avatar
Buy a hole saw for the drill. Simply nothing else works better and you can now buy the lower-end hole saws for less then $12 a set.
When using them, drill/saw most of the way through the GRP, then around to the other side, thread the centre biyt into the pilot hole and finish sawing form the other side, this gives you clean edges on both sides without any gelcoat popping off the edges.
Sasha
Sasha_V is offline
