SailNet Community - View Single Post - Cutting through hole
post #3 of Old 01-07-2008
sailingdog
A holesaw is the way to go. It would be the best tool for cutting a proper hole. They do make adjustable diameter hole saws, but if it is a standard diameter, a regular hole saw should do the trick. Hole saws have a central arbor that you set at the centerpoint of where you want the hole cut.
A three inch diameter hole saw will require a fairly powerful drill.
BTW, if you run the saw in reverse initially, you won't chip the gelcoat as much... then once you're through the gelcoat, switch the drill to forward operation. The idea of using the holesaw from both sides is also an excellent one, and I'd recommend it.
sailingdog is offline
