SailNet Community - View Single Post - Hull/Keel Joint Can of Worms
post #4 of Old 01-09-2008
sailingdog
I think you will probably be better off removing the keel and then resealing it completely. The formation of ice has probably damaged the area to some degree, so dropping the keel and checking for damage would the minimum you should be doing. Might as well bite the bullet and inspect all the keelbolts, as well as the keel and the bilge keel box. Then you can clean it all up, replace any bolts that look questionable, and seal it back up and know it is in good shape rather than worrying about it.
sailingdog is offline
