Old 01-09-2008
sailingdog sailingdog is offline
Good point Chuckles...
You're right AFAICT. The Solent Rig is not the same as Solent stay... The Solent rig is essentially what you and I have on our boats, with a screacher forward of the normal forestay.
The advantages of a Solent rig over a cutter probably have much to do with light air performance. Two smaller sails do not generally provide the same power as a single large sail equal to them in area. However, as you pointed out, a Solent rig isn't designed to fly both headsails at one time generally, and the outer headsail generally sheets outside both forestays.
