Chef2sail:
First of all I hope that you can accept my humble apology. I am sorry that my earlier post came off as being a put down. I in no way intended it that way.
What I did intend to say in abreviated form in the perhaps poorly written sentence in question was three separate points.
1. The sailing qualities and pointing ability of fractionally rigged boats can vary quite widely, just as on masthead boats, and without knowing what specific boats your are racing, its hard for me to comment on their sailing relative abilities.
2. At least at the higher levels of racing, masthead rig boats do not point any higher than fractionally rigged boats, which is partially why so many modern grand prix level race boats are fractionally rigged.
3. In most cruising applications, masthead rigged boats do not point higher or have a better VMG than a comparable masthead rigged boat.
My other point that I intended to make during my post is that the difference in pointing angle that you have observed may not be the result of the differences between fractional and masthead rigs but may be the result of other factors. More specifically, hull and keel form and that fact that the fastest way to sail any particular boat upwind typically varies with the boat's hull and keel typeform as well as rig.
Modern hullforms can have big VMG gains by footing off slightly due to potentially significantly higher speeds through the water and reduced leeway. These kind of boat speed gains when footing a few degrees are less dramatic on older hull and keel designs, such as your C&C 35, and so their best VMG may occur by sailing a few degrees higher than a more modern boat. Different courses for different horses.
Respectfully,
