SailNet Community - View Single Post - Battery question
post #3 of Old 01-10-2008
artbyjody
artbyjody's Avatar
Most of the boats with Shore Power cables running are running the chargers, fridges etc...whatever appliances are hooked in.
As for your battery questions - if it reads 10.4V AFTER it is charged - then you have no holding charge and a dead battery (which will be evident when you try to turn over your motor if it is an inboard.
Typically, if you leave the charger on - as a battery will self discharge left unattended - you'll be ok until the battery just dies. Typical battery life however for a marine battery is only about 2 years however (at least that is the average).
I live in Seattle as well - and as of late we have had freezing temps and that can kill a battery if a charger is not running on it. Marine batteries are not really designed for freezing temps..
I would see if your Guest Charger has a equalize function and reset however...
But - if you are reading 13.4 after charging you should be fine. If after charging it is 10 something or the charger just seems to charge continuously...its time to replace.
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
