Oysterbay-
Most of them area about the same when it comes to maintenance. Getting one that uses off-the-shelf parts is a much better idea than one that is all proprietary parts. I've installed and worked on one brand that is specifically designed to use off-the-shelf parts, to minimize maintenance costs.
Also, get a larger watermaker than you think you need, since they're generally far more energy efficient. For instance, if you need 20 gallons a day, it is often better to get a larger one and run it every two to three days, rather than running a smaller one every day. One reason for this is most watermakers need to be backflushed with water to clear the RO membrane. Running a larger one every other day means you waste less water backflushing the membrane.
BTW, if you do get a watermaker, make sure that the tank it is connected to is never filled with tap water. The chlorine in tap water will destroy the RO membrane in the watermaker.
