SailNet Community - View Single Post - watermaker
Thread: watermaker
post #7 of Old 01-14-2008
speciald
Special Delivery
speciald's Avatar
Send a message via Skype™ to speciald
Cosider the cost. You can buy alot of water for what the watermaker costs. The membranes have a finite life and will need to be replaced, the frequency determined primarily on hours of use. Having said that I have a Village Marine that runs on 110v. and makes 20g./hr. It has been maintenence free over 4 years. I can keep the water tank full with generator time needed to charge batteries and chill the fridge/freezer so their is no measurable fuel use to make water. In a survey done by Bluewater Sailing, the watermaker was the system that was mostlikely to give a cruiser a problem. I run any water going into my tank not from the watermaker through a carbon filter to guard against chlorine and use hydrogen peroxide as a sterilizing agent. One advantage of a watermaker not often considered is that it allows you to carry less water and more fuel on long passages as surplus water tank capacity can be turned into fuel tankage.
speciald is offline
