SailNet Community - View Single Post - Yanmar PTO v-pulley
post #2 of Old 01-15-2008
BarryL
BarryL's Avatar
Hello,
To remove things that don't want to be removed, I have had good luck with heat, cold, and liquid wrench type things. If it were my motor, I would:
- spray liquid wrench liberally around the shaft
- wait 10-15 minutes
- apply heat from a propane torch to the pulley (1 minute or so) (try not to get the shaft too hot, you don't want to put a lot of heat into the engine where you could damage seals)
- wait 10-15 minutes for it to cool
- try and remove the pulley with gentle taps from a hammer on a block of wood, pry bar, etc.
Can't help you with a replacement.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
