How to remove Cutlass bearing?
I own a Crealock 37 Hull # 242.
I replaced the cutlass bearing without removing the rudder.
Remove the prop and look first, how much of the cutlass bearing is exposed? If it exposed more then ¼” than I believe, that you can do it.
I bought a 1and a ¾” cast iron coupling (Home depot) . I drilled and tapped 8 holes around for a 8/32 machine screws, ¼” from one end of the coupling. Than I grind the tips of the screws to a point, to make them work like a set screws.
After removing the small screws that hold the cutlass bearing to its place, I installed the coupling and the set screws into the exposed cutlass bearing. (Try to grip the cutlass as far from the end as possible.) I tighten the screws real good, and than, using a prop puller, I pulled on the coupling and got the bearing out. It takes few minuets, once you have the coupling ready.
The Cutlass bearing is: 1"x1 3/8"x 4"
Reason: More info
