The shank on the Rocna is fairly deep, much more so than the Bruce you've got on in this photo. The reason I think is due to the incredible holding power of the Rocna. You'll definitely have to remove the forward pin. It might squeak under that top pin, but it depends a bit on whether you're planning on getting the 20 kg or 25 kg Rocna.
Originally Posted by labatt
Here's my roller with a Bruce in it... it now has a Delta, which lines up perfectly to pin to the roller when stored. Not knowing the shank shape of the Rocna, any thoughts?
POST.
